I am currently using a Vybrid processor. I have a need to access the e-fuse setting. The tool that we are using are the IAR I-Jet. Can that be used to access the e-fuse setting? What is the process? If not what is the best tool?
Sean
Dear Sean,
Although not a software person, I will try to answer your questions as much as I can:
I am a bit curious - are you asking "in advance", i.e. trying to foresee possible issues, or have you already bumped into real ones while using our code?
Sincerely, Naoum Gitnik.
