Utilite Pro / ArchLinux ARM / OpenGL ES 2.0: gcoHAL_QueryChipCount() SIGSEGV
rex357
I'm successfully building but cannot run an OpenGL ES 2.0 application in the frame buffer. gcoHAL_QueryChipCount() throws a segmentation fault in libGAL.so when I call eglGetDisplay(). I have looked up online but there is no solutions for my particular setup. People talk about Yocto having galcore integrated in the drivers and that fixes their problem. I couldn't find the galcore module in my arch kernel directory. I also do not have the /dev/galcore/ folder. I'm at a loss for a solution at this point. Any help or guidance towards the solution is appreciated.
Labels (2)
