How to build a unique SDK for custom board by i.MX6 Android BSP.
Question asked by Satoshi Shimoda on Mar 13, 2014
Latest reply on May 19, 2014 by John Cihocki
Branched to a new discussion
Hi community,
I have a question about i.MX6DL Android BSP (jb4.3_1.1.0-ga).
Our partner tried sdk buiding by following procedure, but it failed with the attached error log.
[Procedure]
1. Do the procedure from chapter 2.1 to 3.2 written in Android User's Guide (Rev jb4.3_1.1.0).
2. Execute the following command.
make sdk -j4
Actually, our partner should provide a unique SDK for custom bord to a application software vendor.
You know Google releases Android SDK, but it is not used for the custom board because the Android framework expansion is required in this case.
Then, please see my request as below.
[Q]
Could you let me know how to avoid this error?
And if there is other method to prepare unique SDK, could you let me know it, too?
Satoshi Shimoda
Original Attachment has been moved to: sdk_log.txt.zip
