Mfg tool jumping to OS
vasileiostzizil
I connect a Sabre board with OTG. When the Mfg tool reaches the the jumping to OS windows 7 pop up a window that drive needs format in order to use it and the Mfg tool stops
Any solution?
vasileiostzizil
Hello Dan
Yes the MFG Tool Is OK. The format window is irrelevant to the MFG Tool and does not cause any problems to its function.
I solve some issues I had with the ucl file and it is working OK
Rita_Wang
Hi Vasileios,
Does your MFGTool work now?
Best Regards
Dan
vasileiostzizil
Hello Dan
Rita_Wang
Hi Vasileios,
I am glad to hear your MFG Tool is working now. If you have no other questions, would you please help click Correct Answer button. Thank you~~
Have a great day
Best Regards
Dan
Rita_Wang
Hi Vasileios,
Would you please give the picture of Mfg tool stopping or more information? From the information you give, it's hard to detect where the problem is.
Best Regards
Dan
