Help on programming MQX image to NAND flash of MPC5125 board
visakhanc
     I need to program an MQX image to the NAND flash of MP5125 based board using Coewarrior TAP.  According to  'MQX Getting started guide', in the TWR-MPC5125 section, using the 'Ext Nand Download' target is the only way to do this. Can the flash programmer tool of Codewarrior be used for programming the MQX binary image? How to use this tool with MPC5125.
     Thanks in advance
Visakhan
