modify mqx.html page
utsavikalpesh
Contributor V
I am using MQX 4.0 and created new project. I have made this project by adding useful code files(.c, .h) which are being selected from web-havc demo.I also have put web-page folder into my source folder.
The project run successfully and the page of mqx.html run perfectly on browser.
Now I need to modify the mqx.html page.
I already tried MQX 4.0.1 web_hvac demo - modifying web pages but is not modifying html page as per my requirements.I also have a doubt about location of web pages folder so here I am attaching snapshot of web-pages location.Is location of web pages folder placed correctly...??
Plz send me solution........:smileyconfused::smileyconfused:
Tags (3)
Luis_Garabo
Hi Utsavi,
MQX provides the MaKe Trivial FileSystem tool (mktfs.exe). This tool creates C language source file tfs_data.c with constant arrays of binary data of all input directory files. . It is important to mention that any change in the web pages’ source files (*.html, *.js, *.css, etc) will not be reflected until the mktfs.exe tool is executed again to regenerate the tfs_data.c. Then the project in CodeWarrior shall be recompiled and reloaded to see any update.
I recommend you to copy the file C:\Freescale\Freescale_MQX_4_0\tools\mktfs.exe into your "Source" folder. Then modify the content of your .bat file to this:
mktfs.exe web_pages45
pause
After this the file tfs_data.c shall be updated. Compile again your project and the changes should be reflected.
I hope this helps.
Garabo
Luis_Garabo
Hi Utsavi,
pause
I hope this helps.
Garabo
utsavikalpesh
Contributor V
Hey Garabo,
Thnx Thnx Thnx...It is my mistake @ the relative path and I have correct it
and it is working nicelyyyy.....Thnx again
juanamariasalaz
Hi I have the same error ... but you had and could not fix it ..
where it is or how to change the @ relative path ??
:smileyconfused:
utsavikalpesh
Contributor V
Hi Juana,
I am sorry for late reply.
What I did was, I made my folder named as web_pages45 in which I put my web pages. Now I Open my .bat file with notepad and edit like:
mktfs web_pages45
pause
as per Garabo suggest and it works!!.... (here web_pages45 is a folder name in which i put web pages)
I hope that will also works for you.
Utsavi Bharuchwala
utsavikalpesh
Contributor V
Hi Garabo,
Thnx for reply.As you say I put mktfs.exe into my source folder and
followed the required steps as you have mention but still there is no
modifications appear in mqx.html page.
Also the thing I can't get is the modification into .bat file.Should I have
to write an absolute path while I am modifying web_pages to web_pages45.Though
you have explain me wonderfully but still I am not able to modify mqx.html
as per required . Plz help me to sort it out........
