Why would NFS-mounted rootfs be "read-only"?
Question asked by Ed Sutter on Mar 3, 2014
Latest reply on Mar 4, 2014 by Ed Sutter
I have been in the process of reworking the SABRESD linux to run on our custom hardware.
I have been primarily runing with my rootfs NFS-mounted and that has been fine.
Something has changed that has caused my board to boot up with rootfs now read-only.
I have no idea what caused this to change.
My /etc/exports file entry for this is:
/Full_path_to_my_rootfs_directory/my_rootfs *(rw,no_root_squash)
I've run exportfs -a, and my kernel command line is:
console=ttymxc0,115200 ip=dhcp root=/dev/nfs nfsroot=${serverip}:/Full_path_to_my_rootfs_directory/my_rootfs,v3,tcp
Then at bootup, I see this message:
VFS: Mounted root (nfs filesystem) readonly on device 0:11.
I am able to log in however, everything is readonly.
This used to work.
Same server, same client, nothing obvious (related to NFS) has changed.
Any idea what might cause this?
