ACMPO propagation delay for QG/QE
mitchhodges
Hi all,
What is the propagation delay of the ACMP module when using the ACMPO pin for QE/QG microcontrollers?  Datasheet shows "initialization delay" of 1us, if this is equivalent to propagation delay.  How well matched are the ACMP modules in the QE microcontrollers with 2 comparators available?
Looking to use this for a PWM modulator to eliminate on-board comparators if this will work.
Mitch
