In MQX release 4.0.2 in mqx/source/psp/cortex_m/compiler/rv/comp.c
_asm void __user_setup_stackheap(void)
mov r0, #0
mov r2, #0
Should be:
mov r0, #0
mov r2, #0
bx lr
Please update the file in the next software release.
Solved! Go to Solution.
Hi Alex:
Thank you for reporting this. I noticed in the latest MQX version, C:\Freescale\Freescale_MQX_4_1\mqx\source\psp\cortex_m\compiler\rv_uv4\comp.c, this function has changed to
__asm void __user_setup_stackheap(void)
mov r0, #0
mov r2, #0
bx lr
Hi Alex:
mov r0, #0
mov r2, #0
bx lr
