Use of 16bit port NAND with a MPC8306 processor
Question asked by Manuel Ojea on Feb 26, 2014
Latest reply on Feb 27, 2014 by Scott Wood
We are studing to use a NAND Flash device in our design based in a MPC8306.
The NAND flash (128MB) will be connected to the eLBC and using the FCM mode. We plan to use a 16 bit port NAND, but in the reference manual is not clear if we can use this type of memory or only must use a 8 bit port NAND.
My question is: Could we use this 16 bit port NAND or should be replaced with a 8 bit port NAND?
Thank you for your help.
Manuel Ojea
