Hi all,
I have a DEMO9S08SF4 board. I soldered the BDM connector as off my other boards.
My other boards work fine with the USBDM (4.10.6) under CW 10.3 (Win 7 amd64) but I have trouble with this DEMO9S08SF4:
I have problem also under Flashprogrammer with this board (Flashprogrammer work fine with my other boards):
Please I would appreciate any help ...:smileysilly:
Thanks!
Solved! Go to Solution.
Hi ecb,
That's a rather nasty bug introduced when I added support for the PT devices. Deleting one line was required!
Attached is an updated programmer file and GDI files.
Copy the .exe to C:\Program Files (x86)\pgo\USBDM 4.10.6.110 (or similar)
Copy the .dll to C:\Apps\Freescale\CW MCU v10.5\MCU\bin\plugins\support\HC08\gdi (or similar)
The latter files are untested.
Please let me know if this fixes the problems.
I will roll the changes into the next version.
bye
Hi ecb,
bye
Hello pgo,
I love You ! :smileywink:
The problem is solved. Thanks so.
Some idea for my other problem with OSBDM ? (see CW 10.3 & DEMO9S08SF4)
Bye
C.B.
