Hi pgo, I have a problem, I buy a usbdm from ebay, http://www.ebay.com/itm/USBDM-Emulator-BDM-Kinetis-ARM-Support-K60-HCS12-HC08-DSP-Coldfire-/18094673...
I try to read with flash programmer a MKE02Z64VQH, and say that error target, I can't read de chip, this version dont support SWD? best regards
Hi Braulio,
Unfortunately you are correct. The BDM you have is roughly equivalent to USBDM_CF_JMxxCLD_V3 which only supports the JTAG interface that is not available on the MKE02 devices.
This page has a table indicating which programmers support what interfaces:USBDM: USBDM Debugger interface for Freescale RS08,HCS08,HCS12,Coldfire and ARM-Kinetis Devices.
bye
