Audio Format change 16 to 24 bit.
srinivasanshanm
Dear Support Team
We are using ltib L2.6.35_1.1.0_130130_source.
How to change audio format from 16 bit  44.1Khz to 24 bit 44.1Khz in gstreamer & fslplayer in imx 28 board ?
Since we want 24bit PCM audio output to drive our audio codec chip.
Srinivas
Labels (2)
Yuri
You may vary such parameters as sample rate, width as following (example) :
gst-launch-0.10 -e alsasrc device-name=hw:0,0 ! audio/x-raw-int, width=16, depth=16, rate=44100, channels=2 ! queue !  filesink location= /mnt/nfs/sound.raw
srinivasanshanm
We used below  command to configure 24bit PCM output:
gst-launch filesrc location=HugeWAV.wav ! wavparse ! audioconvert ! audioresample ! alsasink ,width=24, depth=24, rate=44100
this command will play song,
It is 16bit wav file but format is not changing to 24bit format.
Please correct the command if iam wrong.
Or is there any option to change the bit format in fslplayer???
Rgds
Srinivas
