About the code of LinuxBSP for MX6_SABRE-SDP
yuuki
Senior Contributor II
I am just going to study Linux.
I received the following questions from our customer.
Would you teach about the code of LinuxBSP for MX6_SABRE-SDP?
Our customer wants to test LED on SABRE-SDP.
They were able to control LED using the "echo" command.
(LED turn ON/OFF)
They want to write the same code as this in C file.
For example,
fd=Open (/dev/xxx, xxxx)
  Write (fd, xxxx)
  Close (fd)
Is there such any sample code?
Which driver should be referred to?
May I have advice?
Labels (2)
Tags (2)
YixingKong
Senior Contributor IV
Yuuki
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the issue, can we close the discussion? If you still need help, please feel free to reply with an update to this discussion.
Yixing
yuuki
Dear Yixing-san,
Thank you for the follow.
I think that I will close this discussion once
Beset Regards,
YixingKong
Yuuki
Thank you for your reply. I am closing the discussion now. Could you share your solution here with others please?
Yixing
