chc08 compiler and WmsgNu command line option.
Question asked by William Hookway on Feb 19, 2014
Latest reply on Feb 19, 2014 by ZhangJennie
I am compiling using chc08 5.0.39 Build 11346.  The CW HC(S)08 Build Tools Manual refers to the WmsgNu command line option to Disable user Messages.  However, when this is included on the command line I get the following
FATAL C50: Input File: 'WmsgNu=abe'  not found
The compile terminates with an "Error occurred while processing", is this a valid option for the chc08 compiler?
As the project is small I am using an unlicensed version of the compiler.
Any suggestions?
Thank You,
Will Hookway
