Hi!
I would like to copy the project and rename it to another code. With this I can generate other files for another versions of the product.
With CodeWarrior ¨it was easier to do this.
I saw in this forum the same doubt but I didn't understand tha solution.
All way that I tried, when I build the project, the result is some file tied to the previous one.
Anyone knows an easier way to do this?
Thanks a lot
Edson
Thanks a lot for your suggestion but I decided to create a new one and import Board Configuration setup. The text of the Processorexpert.c and events.c was copied too.
In this way I think it easier than the procedures in the links.
Edson
Hello Edson:
Copying a project is a complicated procedure. Take a look at the next 2 tutorials by our colleague Erich Styger:
Copy my Project | MCU on Eclipse
Copy my CodeWarrior Project | MCU on Eclipse
Hope this helps!
Jorge Gonzalez
