MC9HCS08QE64 Bootloader
Question asked by Madhu Vatte on Feb 17, 2014
Latest reply on Feb 20, 2014 by Derek Snell
I’m working on porting some boot-loader code from the QE32 microcontroller to the QE64 microcontroller. It looks like the FLASH memory map is a little more complex (with some paging needed). I’m struggling a bit with the “Project.prm” file and the actual code to  copy over to FLASH. Can you help me how to write to the FLASH in a boot-loader scenario using the “doonstack.asm” file? I’m wondering if I’m going down the right path by setting the PAGE (0 – 3) and the writing to address 0x8000 – 0xBFFF? I’ve copied in a code snippet below from my boot-loader. Is there a specific example for the QE64 chip?
     // only pages one and two
    for(index=1; index<3; index++)
      PPAGE_XA_14 = index;
      //erase old program here
      ProgramAddress = 0x8000;
      while(ProgramAddress < 0xBFFF)
        //reset watchdog for each erase cycle
__RESET_WATCHDOG();
        FlashErase((unsigned char*)ProgramAddress);
        ProgramAddress += 512;
__RESET_WATCHDOG();
        FlashProg((unsigned char*)ProgramAddress, value);
        ProgramAddress++;
      value++;
Madhu
