Is it possible to do hardware accelerated scaling of a live video stream and mabye adding a text overlay?
I played a little bit with gstreamer: The texoverlay plugin does exactly what I need, but the frame rate drops to about 0.9 fps when it's active, which is not acceptable.
Is there a better approach than using gstreamer?
