About operation of GPU Application on MCIMX6DL-SDP.
keitanagashima
Senior Contributor I
Hi.
I'd like to operate the GPU Application on MCIMX6DL-SDP.
Now, I'm using "vShader" tool with sample project (=simple.vsp).
But, I couldn't unsderstand a way of the operation of this sample on MCIMX6DL-SDP.
How should I compile the app?
[Environment]
BSP: L3.0.35_4.1.0
VDK: Vivante_VDK-v1.4.6(L3.0.35_4.1.0 BSP).zip
Keita
YixingKong
Senior Contributor IV
Keita
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
YixingKong
Keita
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
joanxie
you can use Eclipse to build the C project, I found an application note for mx31, though this is old one, but maybe you can refer to it, hope helpful for you.
<http://cache.freescale.com/files/dsp/doc/app_note/AN3870.pdf?fpsp=1&WT_TYPE=Application%20Notes&WT_V...>.
