I have a Problem wit the embest MarS Board an the LCD8000.
On the Board runs Android 4.0.4 an its install by image.
The LCD gets correct into sleep mode (e.g. 1min).
But if I touch the screen, the sleep mode will not be resumed.
How can I end the sleep-mode? Can I connect a buton to the board to end the sleep-mode?
Many thanks for your answer!!!
Kind regards,
Chris
I've never used the MarS board, but there is a "wake up capabilities" table in our reference manual:
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
Table 10-1. Aimed power modes
