Cannot boot on SD when SD is present on mmc0 slot
Question asked by francoisrey on Feb 13, 2014
I try to boot Linux version 3.0.35-ts-armv7l with U-Boot 2013.07.
If I put the sd (with linux image and rfs) on mmc0 slot, linux boot crash with the error "VFS: Cannot open root device "mmcblk0p1" or unknown-block(179,1)". If I put the sd on mmc1 slot it works.
I can see that linux detect the mmc0 before trying to open root device, but not mmc1.
Here is the console files of each configuration.
Have you a solution to boot on a SD on mmc0 slot ?
Original Attachment has been moved to: mmc0.txt.zip
Original Attachment has been moved to: mmc1.txt.zip
