an interrupt problem,PE_ISR(Cpu_Interrupt)
Question asked by qiangqiang liu on Feb 12, 2014
Latest reply on Mar 26, 2014 by Petr_H
I'm using Prosessor Expert for the programmation of the K60 tower. I've added a I2C Unit, and i want to use the SendBlock function but at the end of that function, after  the programm stuck in the
  /* This code can be changed using the CPU component property "Build Options / Unhandled int code" */
  PE_DEBUGHALT();
The question is now: what is causing that  fault?
消息编辑者为:qiangqiang liu
