About the difference between the power-on sequence of PMIC and CPU.
Question asked by okamoto satoshi on Feb 11, 2014
Latest reply on Feb 13, 2014 by okamoto satoshi
Hello.
I want to check about i.MX6Q.
There is a difference in power sequence the device(CPU side and PMIC side).
①Which(CPU side and PMIC side) is the right power-on sequence?
②It is not  issue in either the power-on sequence ?
Device you are using is the following:
CPU:MCIMX6Q5EYM10AC
Document order number: IMX6DQ6SDLHDG Rev 1 (2013/06)
Chapter 4  Requirements for Power Management
 4.2 Requirements for a generic interface between chip and PF0100
  Table 4-1.  Interface between the chip and PF0100
 Page 70-71
PMIC:MMPF0100F0AEP
Document order number: MMPF0100 Rev 7.0 (2013/12)
6 Functional Block Requirements and Behaviors
 6.1.1Device Start-up Configuration
  Table 10.  Start-up Configuration
 Page 20-21(Pre-programmed OTP Configuration:F0)
③Why is there a difference in the PMIC and CPU?
-okamoto
