Hi all,
I'm trying to cross-compile my OpenCL program for Sabre-Lite board. When the program is executed on the board, it will tries to compile the GPU kernel code and then run it on the Vivante GPU. My GPU kernel code seems to have some problem, hence the compilation fails, however this online compiler doesn't provide me any error message. I'm wondering if there are any "offline" complier (run on host machine) that provides more detailed error message?
Best,
Chulian
