How to upload a small file , list file , run a file in User Flash memory of Kinetis ?
afdasdfas
Hi all
I need to send a small file to User Flash memory of Kinetis MCU KL25Z . And i can send file ( char or bit ) and write file to User flash by component Serial_LDD ( uart ). But i don't know the way to view list or create a folder of my file or run my file in this .
I attend use QuadPawn and Pawn bytecode to make a file, send them to Kinetis by UART and run it on Kinetis by console.
Thank you
Phuong
Tags (2)
Hui_Ma
Hi Phuong,
It need to use a file system about file operation, you can refer AN4368 software as an example, which is using FAT file system in project.
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4368.pdf
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4368SW.zip
Wish it helps.
Ma Hui
Hui_Ma
Hi Phuong,
Wish it helps.
Ma Hui
