9S08PT32 - The FTMX_CXV register just won't take the value I try to write to it.
Question asked by LARRY MITSCHKE on Feb 8, 2014
Latest reply on Feb 13, 2014 by LARRY MITSCHKE
Even after waiting for the next timer tic where it should load from buffer to registers, the value stays at zero.  I have made sure to write the config registers before loading the value registers, but they stay at zero.   This is the initialization :
FTM0_SC = 0x0B ; // CLKS = 01 or bus clk, PS = 011 or prescale div by 8
FTM2_SC = 0x2B ; // center pwm, CLKS = 01 or bus clk, PS = 011 or prescale div by 8
FTM0_C0SC = 0x40 ;// enable interrupts
FTM0_C1SC = 0x40 ;
FTM2_C5SC = 0x08 ;
FTM0_C0V = FLASH_RESOLUTION ;
FTM0_C1V = (unsigned int) (AUX_TIMER_PERIOD   (FLASH_RESOLUTION / 2));
FTM2_MOD = 0x480 ;// 200 hz PWM
FTM0_CNT = 0 ;// zero the counters
FTM2_CNT = 0 ;
The MOD value takes, though.  Any idea why this is happening?
