USB host select interface error
Question asked by Kristian Rahbek on Feb 9, 2014
I'm using a frdm-kl25z board. I'm trying to connect the board to a
yamaha THR10 amplifier through a USB connection. The USB on
the frdm board is running in host mode.
The goal is to get a pipe handle to endpoint 1 on interface 3. So
far I haven't succeded. The attach event is correctly received but
everytime i run: _usb_hostdev_select_interface() I get an error.
Error nr. 200 / USBERR_NO_DESCRIPTOR.
Any help as to why this happens is greatly appreciated.
I have attached the device descriptor (output of lsusb command
on linux)
Original Attachment has been moved to: lsusb_thr.txt.zip
