how to run two tcp connections at the same time using rtcs ?
Question asked by Handy Chandra on Feb 2, 2014
Latest reply on Feb 10, 2014 by Garabo
I was trying to run two tcp connections at the same time using rtcs. When one tcp socket is running and sending data, i create another tcp socket.
But when i tried to connect it, it fails. Are there some settings i should change to run multiple connections ? i have set max tcp connections to unlimited in user_config.h
