Problem of Processor Expert generated low power BSP code for K60F for 2 MHz clock configuration
Question asked by kiran kunnath on Jan 31, 2014
Latest reply on Feb 14, 2014 by Annie Paul
We are testing low power  mode for K60 Tower board.
Processor Expert generated low power BSP code on for K60F for 2 MHz clock configuration and the VLPR power mode is not working as it is getting stuck in an endless while loop.
while((MCG_S & MCG_S_IRCST_MASK) == 0x00U) { /* Check that the source internal reference clock is fast clock. */
It was mentioned that the CW10.2 version has this problem but it is rectified in CW10.3 version. We are using CW10.5 with MQX 4.0 . but still has this problem.
Kindly provide the solution for resolving the same.
Kiran
