Hi all,
I'm trying to understand how flexNVM partition works.
It seems that th epartition command can not be executed if the memory is already partitioned.
The only way I found is to use Erase All Blocks command before to set a new partition.
Obviously this is not so useful, because of the Erase All Blocks delete my program code also.
What's the correct way to change a partition of a CPU?
Hello:
There is no workaround for the mass-erase. The partitioning is supposed to happen only once.
In application note AN4282 - Using the Kinetis Family Enhanced EEPROM functionality chapter 3.1 you will find the next:
Hope this is useful.
Regards!
Jorge Gonzalez
