Heylo!
I am using a freedom development board.
I want some help on downloading a sample code in the development board and getting starded.
I assume that the open sda mode will download the program.
Can anyone tell me if there is a step by step guide for the same.
Solved! Go to Solution.
Hi Parag,
here are a few suggestions for tutorials:
Erich
Hi Parag,
I suggest that you can also downlaod some relative documents of your board. Assume you have a FRDMKL25Z board, then you could download FRDM-KL25Z User's Manual,
OpenSDA - User Guide,FRDM-KL25Z Schematics, KL25's reference manualetc and datasheet,etc through FRDM-KL25Z: Freescale Freedom Development Platform for Kinetis KL14/15/24/25 MCUs
So you can visist the FSL website to search for some related documents about your board.
I hope my support can help.
Ping
Dear Ping/Erich:
Thanks for your support. The debug utility did work.
I want some step by step guide which will walk me through building simple "Hello World program" and downloading the same to Freedom Board. I have a freedom Development board and working on the same.
Parag
Hi Parag,
Erich
that might depend a little bit on the firmware you have loaded on the board. Usually the FRDM boards ship with an MSD (Mass Storage Device) bootloader, so you can copy S19 files to it, and it will program it.
For debugging you need to switch the firmware to the DebugApp.
OpenSDA on the Freedom KL25Z Board
gives an overview. I recommend that you look at the new P&E firmware (New P&E OpenSDA Firmware v114) which comes with a new bootloader, and has the debug app and MSD app combined. But you can use other firmware too (like from Segger or USBDM).
The reference site hosts as well tutorials and code examples around the FRDM board.
I hope this helps as a starter.
