Could anyone tell me if there is a Freescale chip where there is built-in ethernet phy and switch?
thanks.
i suggest you use Solution Advisor which is very easy to choose the correct device for your requirement.
http://freescale.transim.com/solutionadvisor/SolutionAdvisor.aspx?t=features
