Hi:
I'm using 56F8013 cpu for a project, i use beans to generate the code, and write some extra code on my own, and then compile it, I got the following error message:
Link Error: Undefined : "FArchIO"
Referenced from "FINT_PWM_Reload in INT_PWM_Reload.c"
Since i use PWM reload interrupt to do the ADC sampling and control method, so there must be something wrong with INT_PWM_Reload.c, but so far can't figure it out, need help!
Thanks!
Alban Edit: Please always include FSL Part Number in Message Subject line.
Message Edited by Alban on 2007-09-07 02:39 PM
