I need some of the pins associated with the trace port for my design and need to know if I can debug with just the Vybrid standard interface using the 20 pin header.
Just rephrasing Jiri, "Yes, you can".
/Naoum.
Hi James,
for debug both cores the trace port /lines are not needed.
/Jiri
