Question WDOG_WCR Manual Issue
soichiyamamoto
Contributor V
I ask about  manual issue.
The bit array of a figure is different from a bit array of a table in 26.6.1 Watchdog Control Register (WDOG_WCR)/WDOG_WCR field descriptions .(VYBRIDRM.pdf/1136page )
Is bit array of a table right?
soichi
naoumgitnik
Senior Contributor V
Dear Soichi,
May you clarify, please, what specific difference you are asking about?
Thanks, Naoum Gitnik.
soichiyamamoto
Contributor V
Dear Naoum,
Thank you for reply.
A difference between figure and table is as follows
a figure
  15-8 : WT
     7 : SRE
     6 : WDA
     5 : SRS
     4 : WDE
     3 : WDBG
     2 : WDZST
a table:
 15-8 : WT
     6 : SRE
     5 : WDA
     4 : SRS
     2 : WDE
     1 : WDBG
     0 : WDZST
soichi
a figure:
a table:
naoumgitnik
Dear Soichi,
Sorry for taking that long to answer it, but I got clarification that the the bit mapping in the table is correct.
I will request the documentation correction.
Thanks for catching it!
Regards, Naoum Gitnik.
naoumgitnik
Dear Soichi,
Any success so far with our published code, please?
naoumgitnik
Dear Soichi,
It looks to me like a typo.
Before starting checking it with the design team, may I ask you if you verified the bits use/descriptions in our published code? - This code is tested and quite well commented, therefore it is a trusted source of information.
