I am using CW v10.3 SE with a MC56F84789 micro. When i use processor expert AND printf, the debugger hangs at 99% while loading the micro, however if i create a blank project without PE and utilize printf, the entire binary loads and i am able to use the debugger. Any suggestions will be greatly appreciate. Thanks!
Solved! Go to Solution.
Since you are using Special Edition, I would recommend updating to CW10.5, it can be downloaded from:
If the problem still exist, please attach your project.
v10.5 worked, thanks!
