How to use the FTM for CPWM output?
changkenta
I want to use the FTM for 6 channel CPWM output for 3-phase motor control, and on the MK60DN512VLL10 datasheet and reference manual do not show it. Is there any document for me to know How to setting the FTM to generate 6 channel CPWM output?
Kenta
kerryzhou
Hi Kenta,
    If your question is solved, could you mark your question as solved?
    Thank you very much!
Jingjing
kerryzhou
Hi Kenta,
     Please find the application note in the attachments, maybe it is useful to you!
    By the way, there has another post:K60 PWM phase?  for your reference!
    Wish it helps you!
Best regards!
Jing
changkenta
Hi Jingjing,
Thanks.
by the way, I hope to setting FTM generate 6 channel CPWM output by Processor Expert, but do not succeed.
please let me know How to do it?
kenta
kerryzhou
Hi Kenta,
    I create a project base on TWR-K60D100M, and use the PE,  choose init_FTM component .
    Now in my project, I configure 2 channels, and test OK, you can refer to it, and create the other 4channels.
   My configuration is as follows,  please find my project from the attachments.
The test result is :
Wish it helps you!
If you still have question, please contact me!
Thank you and best regards!
Jing
changkenta
hi Jingjing,
thanks. I can setting FTM to generate CPWM output.
next, I want to study hot to update the PWM-duty for Sine PWM algorithm?
Kenta
kerryzhou
Hi Kenta,
    About how update the PWM-duty for sine PWM algorithm, please find it in the AN3729 which I already give you!
   chapter 3.2 sine wave generation.
   By the way, this AN maybe help you too,  the link is :
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4429.pdf?fromsite=zh-Hans
Best regards!
Jing
changkenta
hi Jingjing,
thanks for your share.
I found, I can not update the FTM0_CnV in PE_ISR(FTM_OVER). could you please let me know: How to update the FTM0_C0V, FTM0_C1V?
Kenta
kerryzhou
Hi Kenta,
    I already try it, the PWM-duty can be changed in the interrupt function. Of course, this method is not work in PWM synchronization.
    I don't know how you to update the FTM0_C0V. I use the following code. you can try it!
/* User includes (#include below this line is not maintained by Processor Expert) */
PE_ISR(FTM_OVER)
// NOTE: The routine should include actions to clear the appropriate
//      interrupt flags.
      FTM0_SC  &= ~FTM_SC_TOF_MASK;
      FTM0_C0SC &= ~FTM_CnSC_CHF_MASK ;
      FTM0_C1SC &= ~FTM_CnSC_CHF_MASK ;
      /* FTM0_C0V: ??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,VAL=0x05DC */
      FTM0_C0V = FTM_CnV_VAL(0x05DC);
      /* FTM0_C1V: ??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,VAL=0x05DC */
      FTM0_C1V = FTM_CnV_VAL(0x07D0);
In this code, I just change the FTM0_C1V from 1500(0x05DC) to 2000(0x07D0), and the result is as follows, you will find the duty of C1 is changed.
If you still have question, please contact with me!
I wish my answer is useful to you!
Best regards!
Jingjing
changkenta
hi Jingjing,
Yes, do not work in PWM sync.
I follow your code, and FTM0_C0V is updated.
thank you.
another Question is: I Do not know How to setting K60 after power on reset, immediately Run the code?
please let me know ...
Kenta
kerryzhou
Hi Kenta,
   Could you describe your question in details?
   What do you want to setting?
Jingjing
changkenta
hi Jingjing,
I found that after I download the code into K60, and power Off the K60 board, then re-power On the K60 board, the K60 do not Run the code.
is this the power On reset setting issue ?
Kenta
kerryzhou
Hi Kenta,
   Please configure like this picture:
make sure in Flash, not in RAM.
Then download the code.
Wish it helps you!
Best regards!
Jingjing
changkenta
hi Jingjing,
follow the Flash configure, ... the code is Running after power On.
thank you so much.
Kenta
kerryzhou
Hi Kenta,
Jingjing
changkenta
hi Jingjing,
Yes, but I am a new guy, please let me know How to mark my question is solved?
Kenta
kerryzhou
Hi Kenta,
   You already done it!
   Just mark the correct answer!
Best regards!
Jingjing
