P2020RDB boot probem
Question asked by Hu Yang on Dec 13, 2013
Latest reply on Nov 3, 2014 by Scott Wood
Hi there,
I have a problem with my P2020rdb-PC borad when boot the linux kernal in uboot.
The booting msg is shown as below:
=> bootm ef080000 2000000 ef040000
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at ef080000 ...
   Image Name: Linux-3.8.13-rt9-QorIQ-SDK-V1.4
   Created:      2013-06-15   2:52:10 UTC
   Image Type:   PowerPC Linux Kernel Image (gzip compressed)
   Data Size:    3985858 Bytes = 3.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 02000000 ...
   Image Name: fsl-image-core-p2020rdb-20130615
   Created:      2013-06-15   3:32:21 UTC
   Image Type:   PowerPC Linux RAMDisk Image (gzip compressed)
   Data Size:    22026054 Bytes = 21 MiB
## Flattened Device Tree blob at ef040000
   Booting using the fdt blob at 0xef040000
   Uncompressing Kernel Image ... OK
   Loading Ramdisk to 2eafe000, end 2ffff746 ... OK
   Loading Device Tree to 03ff6000, end 03fff2c6 ... OK
WARNING: could not find compatible node fsl-usb2-dr: FDT_ERR_NOTFOUND.
Using P2020RDB-PC machine description
Memory CAM mapping: 256/256/256 Mb, residual: 256Mb
Linux version 3.8.13-rt9-QorIQ-SDK-V1.4 (jenkins@topsy) (gcc version 4.7.2 (GCC3
Found initrd at 0xeeafe000:0xeffff746
CPU maps initialized for 1 thread per core
bootconsole [udbg0] enabled
setup_arch: bootmem
mpc85xx_rdb_setup_arch()
mpc85xx_rdb_setup_arch: Could not find Quicc Engine node
MPC85xx RDB board from Freescale Semiconductor
arch: exit
Zone ranges:
  DMA      [mem 0x00000000-0x2fffffff]
  Normal   empty
  HighMem  [mem 0x30000000-0x3fffffff]
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x00000000-0x3fffffff]
MMU: Allocated 1088 bytes of context maps for 255 contexts
PERCPU: Embedded 7 pages/cpu @c112b000 s6432 r8192 d14048 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
Kernel command line: root=/dev/ram rw ramdisk_size=10000000 console=ttyS0,115200
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 942548k/1048576k available (7724k kernel code, 106028k reserved, 300k d)
Kernel virtual memory layout:
  * 0xfff5f000..0xfffff000  : fixmap
  * 0xffc00000..0xffe00000  : highmem PTEs
  * 0xffbfd000..0xffc00000  : early ioremap
  * 0xf1000000..0xffbfd000  : vmalloc & ioremap
SLUB: Genslabs=15, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
        RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
NR_IRQS:512 nr_irqs:512 16
mpic: Setting up MPIC " OpenPIC  " version 1.2 at ffe40000, max 2 CPUs
mpic: ISU size: 256, shift: 8, mask: ff
mpic: Initializing for 256 sources
mpc85xx_rdb_pic_init: Could not find qe-ic node
clocksource: timebase mult[a000000] shift[24] registered
Console: colour dummy device 80x25
Mount-cache hash table entries: 512
mpic: requesting IPIs...
Brought up 2 CPUs
devtmpfs: initialized
Found FSL PCI host bridge at 0x00000000ffe09000. Firmware bus number: 0->0
PCI host bridge /pcie@ffe09000 (primary) ranges:
MEM 0x00000000a0000000..0x00000000bfffffff -> 0x00000000a0000000
  IO 0x00000000ffc10000..0x00000000ffc1ffff -> 0x0000000000000000
/pcie@ffe09000: PCICSRBAR @ 0xfff00000
Found FSL PCI host bridge at 0x00000000ffe0a000. Firmware bus number: 0->0
PCI host bridge /pcie@ffe0a000  ranges:
MEM 0x0000000080000000..0x000000009fffffff -> 0x0000000080000000
  IO 0x00000000ffc00000..0x00000000ffc0ffff -> 0x0000000000000000
/pcie@ffe0a000: PCICSRBAR @ 0xfff00000
PCI: Probing PCI hardware
fsl-pci ffe09000.pcie: PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
pci_bus 0000:00: root bus resource [mem 0xa0000000-0xbfffffff]
pci_bus 0000:00: root bus resource [bus 00-ff]
pci 0000:00:00.0: ignoring class 0x0b2000 (doesn't match header type 01)
pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0000:00:00.0: PCI bridge to [bus 01-ff]
fsl-pci ffe0a000.pcie: PCI host bridge to bus 0001:02
pci_bus 0001:02: root bus resource [io  0x20000-0x2ffff] (bus address [0x0000-0)
pci_bus 0001:02: root bus resource [mem 0x80000000-0x9fffffff]
pci_bus 0001:02: root bus resource [bus 02-ff]
pci 0001:02:00.0: ignoring class 0x0b2000 (doesn't match header type 01)
pci 0001:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0001:02:00.0: PCI bridge to [bus 03-ff]
pci 0000:00:00.0: PCI bridge to [bus 01]
pci 0000:00:00.0: bridge window [io  0x0000-0xffff]
pci 0000:00:00.0: bridge window [mem 0xa0000000-0xbfffffff]
pci 0001:02:00.0: PCI bridge to [bus 03]
pci 0001:02:00.0: bridge window [io 0x20000-0x2ffff]
pci 0001:02:00.0: bridge window [mem 0x80000000-0x9fffffff]
pci 0000:00:00.0: enabling device (0106 -> 0107)
pci 0001:02:00.0: enabling device (0106 -> 0107)
fsl-l2ctlr ffe20000.l2-cache-controller: Entire L2 as cache, provide valid srame
fsl-l2ctlr: probe of ffe20000.l2-cache-controller failed with error -22
bio: create slab <bio-0> at 0
Freescale Elo / Elo Plus DMA driver
fsl-elo-dma ffe0c300.dma: #0 (fsl,eloplus-dma-channel), irq 76
fsl-elo-dma ffe0c300.dma: #1 (fsl,eloplus-dma-channel), irq 77
fsl-elo-dma ffe0c300.dma: #2 (fsl,eloplus-dma-channel), irq 78
fsl-elo-dma ffe0c300.dma: #3 (fsl,eloplus-dma-channel), irq 79
fsl-elo-dma ffe21300.dma: #0 (fsl,eloplus-dma-channel), irq 20
fsl-elo-dma ffe21300.dma: #1 (fsl,eloplus-dma-channel), irq 21
fsl-elo-dma ffe21300.dma: #2 (fsl,eloplus-dma-channel), irq 22
fsl-elo-dma ffe21300.dma: #3 (fsl,eloplus-dma-channel), irq 23
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@>
PTP clock support registered
Advanced Linux Sound Architecture Driver Initialized.
Switching to clocksource timebase
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 21512k freed
Freescale PMC driver
audit: initializing netlink socket (disabled)
type=2000 audit(0.404:1): initialized
bounce pool size: 64 pages
HugeTLB registered 1 MB page size, pre-allocated 0 pages
HugeTLB registered 4 MB page size, pre-allocated 0 pages
HugeTLB registered 16 MB page size, pre-allocated 0 pages
HugeTLB registered 64 MB page size, pre-allocated 0 pages
HugeTLB registered 256 MB page size, pre-allocated 0 pages
HugeTLB registered 1 GB page size, pre-allocated 0 pages
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NTFS driver 2.1.30 [Flags: R/O].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 1501
io scheduler noop registered
Freescale Display Interface Unit (DIU) framebuffer driver
Serial: 8250/16550 driver, 2 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0xffe04500 (irq = 42) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0xffe04600 (irq = 42) is a 16550A
Generic non-volatile memory driver v1.1
brd: module loaded
loop: module loaded
nbd: registered device at major 43
st: Version 20101219, fixed bufsize 32768, s/g segs 256
ef000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x00001
Amd/Fujitsu Extended Query Table at 0x0040
  Amd/Fujitsu Extended Query version 1.3.
number of CFI chips: 1
5 ofpart partitions found on MTD device ef000000.nor
Creating 5 MTD partitions on "ef000000.nor":
0x000000000000-0x000000040000 : "NOR Vitesse-7385 Firmware"
ftl_cs: FTL header not found.
0x000000040000-0x000000080000 : "NOR DTB Image"
0x000000080000-0x000000400000 : "NOR Linux Kernel Image"
0x000000400000-0x000000f00000 : "NOR JFFS2 Root File System"
0x000000f00000-0x000001000000 : "NOR U-Boot Image"
NAND device: Manufacturer ID: 0xec, Chip ID: 0x75 (Samsung NAND 32MiB 3,3V 8-bi6
Bad block table found at page 65504, version 0x01
Bad block table found at page 65472, version 0x01
6 ofpart partitions found on MTD device ff800000.flash
Creating 6 MTD partitions on "ff800000.flash":
0x000000000000-0x000000100000 : "NAND U-Boot Image"
fsl-lbc ffe05000.localbus: Parity or Uncorrectable ECC error: LTESR 0x20000001
fsl,elbc-fcm-nand ff800000.nand: command failed: fir 412e0000 fcr 0 status 20000
0x000000100000-0x000000200000 : "NAND DTB Image"
0x000000200000-0x000000600000 : "NAND Linux Kernel Image"
0x000000600000-0x000000a00000 : "NAND Compressed RFS Image"
0x000000a00000-0x000001100000 : "NAND JFFS2 Root File System"
0x000001100000-0x000002000000 : "NAND Writable User area"
eLBC NAND device at 0xff800000, bank 1
fsl_espi ffe07000.spi: master is unqueued, this is deprecated
m25p80 spi32766.0: found s25sl12801, expected m25p80
m25p80 spi32766.0: s25sl12801 (16384 Kbytes)
5 ofpart partitions found on MTD device spi32766.0
Creating 5 MTD partitions on "spi32766.0":
0x000000000000-0x000000080000 : "SPI U-Boot Image"
0x000000080000-0x000000100000 : "SPI DTB Image"
0x000000100000-0x000000500000 : "SPI Linux Kernel Image"
0x000000500000-0x000000900000 : "SPI Compressed RFS Image"
0x000000900000-0x000001000000 : "SPI JFFS2 RFS"
fsl_espi ffe07000.spi: at 0xf10c2000 (irq = 59)
libphy: Fixed MDIO Bus: probed
libphy: Freescale PowerQUICC MII Bus: probed
fsl-gianfar ffe24000.ethernet: ptp 1588 is initialized.
fsl-gianfar ffe24000.ethernet eth0: mac: 00:04:9f:02:00:fd
fsl-gianfar ffe24000.ethernet eth0: Running with NAPI enabled
fsl-gianfar ffe24000.ethernet eth0: RX BD ring size for Q[0]: 256
fsl-gianfar ffe24000.ethernet eth0: TX BD ring size for Q[0]: 256
fsl-gianfar ffe25000.ethernet: ptp 1588 is initialized.
fsl-gianfar ffe25000.ethernet eth1: mac: 00:04:9f:02:01:fd
fsl-gianfar ffe25000.ethernet eth1: Running with NAPI enabled
fsl-gianfar ffe25000.ethernet eth1: RX BD ring size for Q[0]: 256
fsl-gianfar ffe25000.ethernet eth1: TX BD ring size for Q[0]: 256
fsl-gianfar ffe26000.ethernet: ptp 1588 is initialized.
fsl-gianfar ffe26000.ethernet eth2: mac: 00:04:9f:02:02:fd
fsl-gianfar ffe26000.ethernet eth2: Running with NAPI enabled
fsl-gianfar ffe26000.ethernet eth2: RX BD ring size for Q[0]: 256
fsl-gianfar ffe26000.ethernet eth2: TX BD ring size for Q[0]: 256
pps pps0: new PPS source ptp0
ucc_geth: QE UCC Gigabit Ethernet Controller
e1000e: Intel(R) PRO/1000 Network Driver - 2.1.4-k
e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
ehci-pci: EHCI PCI platform driver
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
And it just stuck there, it seems have some problem with USB module on board, is that correct?
Our uboot file, uImage file, file system and dtb file were all from SDK1.4.
Is there any one have similar problem?
Thanks for all your help in community.
Hu
