Where is the library for the "Digital Signal Processing Libraries Using the ColdFire ® eMAC and MAC"?
Question asked by Shaun James on Dec 9, 2013
Latest reply on Dec 10, 2013 by Shaun James
This library is thoroughly documented in this document http://www.freescale.com/files/32bit/doc/ref_manual/DSPLIBUM.pdf:
Using the ColdFire® eMAC and MAC
User’s Manual
DSPLIBUM
Rev. 1.2
03/2006
... but I cannot find the accompanying library file anywhere.  The closest that I can get is this page: CFDSPLIB: Complimentary ColdFire Digital Signal Processing Library which also has no download.  It appears that you set up your high/low/band pass filter parameters here, and then download an XML file which mentions signal processing .c and .h files, but the files are not provided.  Also, this page only has band pass/stop filters, whereas the library I am looking for has FFT, FIR and IIR.
Does anyone have a link to download these files?
Shaun
