Hi Regster of SRC_SCR[CM4_WDGRST_MASK] or SRC_SCR[CA5_WDGRST_MASK] control wdog_rst_b. What is wdog_rst_b? IO? Explanation of wdog_rst_b is not written in Reference Manual. Best regards, soichi
Solved! Go to Solution.
Dear Soichi,
As per the Design team, "when the watchdog’s counter expires, it asserts the 'wdog_reset_b' internal signal; we have mapped this signal as a source of reset in SRC".
Thanks for pointing at the fact that it needs to be described better in the next Reference Manual revision.
Regards, Naoum Gitnik.
Dear Soichi,
Dear Soichi,
I am still checking it with the Design team.
