Hi developers,
I am trying to build image for Freescale SABRE-AI board using LTIB.
I am working from behind corporate proxy.
According to the documentation, i have done following changes to the ~/.ltibrc file
%http_proxy
http://<usr>:<password>@<proxyserver.com>:8080
My ppp_url and gpp_url are as follows:
%ppp_url
http://auslxsc01.am.freescale.net/ppp/
%gpp_url
(BOTH OF THESE LINKS ARE NOT OPENING THROUGH BROWSER).
I have also set %ppp_proxy,%gpp_proxy, %gpp_stage_proxy,%cpp_stage_proxy to 1.
When LTIB tries to access some of the packages from gpp, i get the following error.
Processing: libmad
Build path taken because: no prebuilt rpm,
Testing network connectivity
Testing proxy connection for PPP : FAIL
response was: 500 Can't connect to <username>:<password>:80
Can't get ppp index, proxy forced off
Testing proxy connection for GPP : FAIL
Can't get gpp index, proxy forced off
No network download connection available
My internet works fine, since I can download other things using curl,wget,sudo apt-get etc.
Plz assist me with this.
Thanks and regards,
Prathamesh Ghanekar
