Thanks for the reply so quickly!
I have figured out my problem, despite the checks on the Baud Rates they still were the source...
I was calculating my baud rate based on a 18.97MHz Bus and not a 18.87MHz bus which caused all my headaches. Fixing this calculation seems to have solved my problem!
Thanks again.
