How to use I2c
How to use I2c
jikehe
volatile bool DataReceivedFlg = FALSE;
volatile bool DataTransmittedFlg = FALSE;
uint8_t OutData[4] = {0x00U, 0x01U, 0x02U, 0x03U};
uint8_t InpData[4];
LDD_TError Error;
LDD_TDeviceData *MyI2CPtr;
int main(void)
  PE_low_level_init();
  MyI2CPtr = I2C2_Init(NULL);
  while(1)
    Error = I2C2_SlaveReceiveBlock(MyI2CPtr, &InpData, 4U);
    if(TRUE == DataReceivedFlg)
        I2C2_SendAcknowledge(MyI2CPtr, LDD_I2C_ACK_BYTE);
no ack signal
Robin_Shen
I am sorry , I can't understand your problem clearly.
Can you describe the problem clearly?
Do you want find where you can enable "I2C2_SendAcknowledge" function in CodeWarrior with PE?
Robin_Shen
Do you want send NACK signal?
I2C2_SendAcknowledge(MyI2CPtr, LDD_I2C_NACK_BYTE);
jikehe
I use mk10dx256vlq10 mcu, I use codewarrior 10.4 tool, I2C_LDD component Settings->Mode selection selected SLAVE.
uint8_t InpData[4];
LDD_TError Error;
int main(void)
  while(1)
no ack signal
perlam_i_au
Senior Contributor I
Here you can find different Application notes for use I2C, could you be a bit specific about what are you trying to do? or at least could you mention an error or problem, I could search specific solutions, with more information.
Please tell me if this is useful. :smileygrin:
