Crash in gcoHAL_QueryChipCount when initializing OpenGLES on i.MX6D
Question asked by Huib-Jan Imbens on Nov 22, 2013
Latest reply on Dec 16, 2013 by Einar Bjorgvinsson
On a MarSBoard with i.MX6 dual ( http://www.embest-tech.com/shop/star/marsboard.html ) I installed a yocto image build using recipes from silmerusse/meta-robomind
After installing I copiedIndex of /buildsources/g/gpu-viv-bin-mx6q/gpu-viv-bin-mx6q-1.1.0 over /usr.
A simple OpenGLES 2.0 app built with -DEGL_API_FB=1 crashes in gcoHAL_QueryChipCount.
A stacktrace:
#0  0x2ab19984 in gcoHAL_QueryChipCount () from /usr/lib/libGAL.so
#1  0x2aaf8ad0 in veglGetThreadData () from /usr/lib/libEGL.so
#2  0x2aaf1f30 in eglGetDisplay () from /usr/lib/libEGL.so
#3  0x00068634 in OpenGLApplication::InitOpenGL (this=0x7efff950) at application.cpp:859
#4  0x00017d70 in main (argc=1, argv=0x7efffd04) at consoleapp.cpp:368
Site of crash:
(gdb) x/8i $pc-16
   0x2ab19974 <gcoHAL_QueryChipCount+28>:       str     r2, [r4]
   0x2ab19978 <gcoHAL_QueryChipCount+32>:
    ldr r2, [pc, #8388608]      ; 0x2ab199d0 <gcoHAL_QueryChipCount+120>
   0x2ab1997c <gcoHAL_QueryChipCount+36>:       ldr     r3, [r3, r2]
   0x2ab19980 <gcoHAL_QueryChipCount+40>:       ldr     r3, [r3, #2809676]
=> 0x2ab19984 <gcoHAL_QueryChipCount+44>:       ldr     r3, [r3, #2809676]
   0x2ab19988 <gcoHAL_QueryChipCount+48>:       sub     r2, r3, #1
   0x2ab1998c <gcoHAL_QueryChipCount+52>:       cmp     r2, #2
   0x2ab19990 <gcoHAL_QueryChipCount+56>:
    bhi 0x2ab199ac <gcoHAL_QueryChipCount+84>
I tried to use gpu-viv-bin-mx6q-3.0.35-4.0.0 (using the softfp files) instead of gpu-viv-bin-mx6q-1.1.0 with similar results.
My questions are:
How does one determine the gpu-viv-bin-mx6q version to use?
How do I fix this crash?
