where can i get libfslmsparser-3.0.7-2.tar.gz file?
geekay
ltib doesn't find any link for download. also google. is that some kind of weird joke, freescale?
Labels (3)
AnkurGandhi
I have same problem while compiling Linux BSP for Ltib.
Can't get: libfslmsparser-3.0.7-2.tar.gz at ./ltib line 802.
f_buildrpms() returned an error, exiting
traceback:
main:572
Please let me know where to find the tarball.
geekay
so i decided to manually download missing packages from another place and put it to /opt/freescale/pkgs. i've found libfslmsparser-3.0.2.tar.gz at Sony Global - Source Code Distribution Service :smileyalert:  and edited dist/lfs-5.1/fsl-mm/libfslmsparser.spec to set the required version to 3.0.2. the checksum also was made with md5sum. compiled ok. i guess the answer is somewhere around finding proper packages manually.
AnkurGandhi
Thanks Konstantin for reply.
When I followed your steps, I could move ahead in LTIB compilation. Though I wonder if there could be some licensing issue for using this package. So I might drop the package from my build itself!
