MFS file system corrruption
brentwilliams
Hello I am using a Kinetis K20 part on a custom board.  I am testing a file system (MFS) and I notice that the following test works most of the time, but occasionally I see corruption. The test is simple.  I write 50 files to flash and do a ls.  The results are below.  Has anyone seen something similar?
In a good case I see the following:
ls
FOO1.XML 15001 01-31-1980 01:05:44      A FOO1.XML
FOO2.XML 15001 01-31-1980 01:05:48      A FOO2.XML
FOO3.XML 15001 01-31-1980 01:05:52      A FOO3.XML
FOO4.XML 15001 01-31-1980 01:05:54      A FOO4.XML
FOO5.XML 15001 01-31-1980 01:05:58      A FOO5.XML
FOO6.XML 15001 01-31-1980 01:06:00      A FOO6.XML
FOO7.XML 15001 01-31-1980 01:06:04      A FOO7.XML
FOO8.XML 15001 01-31-1980 01:06:08      A FOO8.XML
FOO9.XML 15001 01-31-1980 01:06:10      A FOO9.XML
FOO10.XML 15001 01-31-1980 01:06:14      A FOO10.XML
FOO11.XML 15001 01-31-1980 01:06:18      A FOO11.XML
FOO12.XML 15001 01-31-1980 01:06:20      A FOO12.XML
FOO13.XML 15001 01-31-1980 01:06:24      A FOO13.XML
FOO14.XML 15001 01-31-1980 01:06:28      A FOO14.XML
FOO15.XML 15001 01-31-1980 01:06:36      A FOO15.XML
FOO16.XML 15001 01-31-1980 01:06:40      A FOO16.XML
FOO17.XML 15001 01-31-1980 01:06:42      A FOO17.XML
FOO18.XML 15001 01-31-1980 01:06:46      A FOO18.XML
FOO19.XML 15001 01-31-1980 01:06:50      A FOO19.XML
FOO20.XML 15001 01-31-1980 01:06:52      A FOO20.XML
FOO21.XML 15001 01-31-1980 01:06:56      A FOO21.XML
FOO22.XML 15001 01-31-1980 01:07:00      A FOO22.XML
FOO23.XML 15001 01-31-1980 01:07:04      A FOO23.XML
FOO24.XML 15001 01-31-1980 01:07:06      A FOO24.XML
FOO25.XML 15001 01-31-1980 01:07:10      A FOO25.XML
FOO26.XML 15001 01-31-1980 01:07:12      A FOO26.XML
FOO27.XML 15001 01-31-1980 01:07:16      A FOO27.XML
FOO28.XML 15001 01-31-1980 01:07:20      A FOO28.XML
FOO29.XML 15001 01-31-1980 01:07:22      A FOO29.XML
FOO30.XML 15001 01-31-1980 01:07:26      A FOO30.XML
FOO31.XML 15001 01-31-1980 01:07:30      A FOO31.XML
FOO32.XML 15001 01-31-1980 01:07:34      A FOO32.XML
FOO33.XML 15001 01-31-1980 01:07:36      A FOO33.XML
FOO34.XML 15001 01-31-1980 01:07:40      A FOO34.XML
FOO35.XML 15001 01-31-1980 01:07:44      A FOO35.XML
FOO36.XML 15001 01-31-1980 01:07:46      A FOO36.XML
FOO37.XML 15001 01-31-1980 01:07:50      A FOO37.XML
FOO38.XML 15001 01-31-1980 01:07:54      A FOO38.XML
FOO39.XML 15001 01-31-1980 01:07:56      A FOO39.XML
FOO40.XML 15001 01-31-1980 01:08:00      A FOO40.XML
FOO41.XML 15001 01-31-1980 01:08:04      A FOO41.XML
FOO42.XML 15001 01-31-1980 01:08:06      A FOO42.XML
FOO43.XML 15001 01-31-1980 01:08:10      A FOO43.XML
FOO44.XML 15001 01-31-1980 01:08:14      A FOO44.XML
FOO45.XML 15001 01-31-1980 01:08:16      A FOO45.XML
FOO46.XML 15001 01-31-1980 01:08:20      A FOO46.XML
FOO47.XML 15001 01-31-1980 01:08:24      A FOO47.XML
FOO48.XML 15001 01-31-1980 01:08:28      A FOO48.XML
FOO49.XML 15001 01-31-1980 01:08:30      A FOO49.XML
FOO50.XML 15001 01-31-1980 01:08:34      A FOO50.XML
In a bad case I am seeing:
ls
FOO1.XML 15001 01-31-1980 00:33:28      A FOO1.XML
FOO2.XML 15001 01-31-1980 00:33:32      A FOO2.XML
FOO3.XML 15001 01-31-1980 00:33:34      A FOO3.XML
FOO4.XML 15001 01-31-1980 00:33:38      A FOO4.XML
FOO5.XML 15001 01-31-1980 00:33:42      A FOO5.XML
FOO6.XML 15001 01-31-1980 00:33:44      A FOO6.XML
FOO7.XML 15001 01-31-1980 00:33:48      A FOO7.XML
FOO8.XML 15001 01-31-1980 00:33:52      A FOO8.XML
FOO9.XML 15001 01-31-1980 00:33:54      A FOO9.XML
FOO10.XML 15001 01-31-1980 00:33:58      A FOO10.XML
FOO11.XML 15001 01-31-1980 00:34:02      A FOO11.XML
FOO12.XML 15001 01-31-1980 00:34:08      A FOO12.XML
FOO13.XML 15001 01-31-1980 00:34:10      A FOO13.XML
FOO14.XML 15001 01-31-1980 00:34:14      A FOO14.XML
FOO15.XML 15001 01-31-1980 00:34:18      A FOO15.XML
FOO16.XML 15001 01-31-1980 00:34:20      A FOO16.XML
FOO17.XML 15001 01-31-1980 00:34:24      A FOO17.XML
FOO18.XML 15001 01-31-1980 00:34:28      A FOO18.XML
FOO19.XML 15001 01-31-1980 00:34:30      A FOO19.XML
FOO20.XML 15001 01-31-1980 00:34:34      A FOO20.XML
FOO21.XML 15001 01-31-1980 00:34:38      A FOO21.XML
FOO22.XML 15001 01-31-1980 00:34:40      A FOO22.XML
FOO23.XML 15001 01-31-1980 00:34:44      A FOO23.XML
FOO24.XML 15001 01-31-1980 00:34:48      A FOO24.XML
FOO25.XML 15001 01-31-1980 00:34:50      A FOO25.XML
FOO26.XML 15001 01-31-1980 00:34:54      A FOO26.XML
FOO27.XML 15001 01-31-1980 00:34:58      A FOO27.XML
FOO28.XML 15001 01-31-1980 00:35:04      A FOO28.XML
FOO29.XML 15001 01-31-1980 00:35:08      A FOO29.XML
FOO30.XML 15001 01-31-1980 00:35:10      A FOO30.XML
FOO31.XML 15001 01-31-1980 00:35:14      A FOO31.XML
FOO32.XML 15001 01-31-1980 00:35:18      A FOO32.XML
FOO33.XML    4294967295 15-31-2107 31:63:62      A FOO33.XML
FOO42.XML 15001 01-31-1980 00:35:50      A FOO42.XML
FOO43.XML 15001 01-31-1980 00:35:56      A FOO43.XML
FOO44.XML 15001 01-31-1980 00:36:00      A FOO44.XML
FOO45.XML 15001 01-31-1980 00:36:04      A FOO45.XML
FOO46.XML 15001 01-31-1980 00:36:08      A FOO46.XML
FOO47.XML 15001 01-31-1980 00:36:10      A FOO47.XML
FOO48.XML 15001 01-31-1980 00:36:14      A FOO48.XML
FOO49.XML 15001 01-31-1980 00:36:18      A FOO49.XML
FOO50.XML 15001 01-31-1980 00:36:20      A FOO50.XML
I monitor the physical address I am writing to and output to a terminal window.  In both of these cases the last physical address it is writing to is the same.
So I believe it is getting into the flash.
Brent
pbanta
Did you ever discover the cause of this issue?
Thanks.
lucky06200
I have sometimes same problem. I do not have explaination about.
I use also MFS, but on a K60 CPU.
Directory entry (and particullary date/time) seems to be corrupted.
On filezilla (accessing file thru ftp) this is a problem, filezillz do not want use file with incorrect date/time.
