gst-plugins-bad - build failure mx6
lionxmx
Hi all,
I build the Linux BSP (L3.0.35_4.0.0).
Host PC: Ubuntu 10.04
I'm trying to compile gst-plugins-bad package but i get the following error:
using config/platform/imx/.config
Processing: fake-provides
Processing: u-boot-v2009.08
Processing: kernel-3.0.35
Processing: skell
Processing: base_libs
Processing: busybox
Processing: libtermcap
Processing: bash
Processing: zlib
Processing: ncurses
Processing: iproute
Processing: openssl
Processing: hotplug
Processing: expat
Processing: freetype
Processing: fontconfig
Processing: libpng
Processing: libjpeg
Processing: glib2
Processing: tslib
Processing: randrproto
Processing: renderproto
Processing: fixesproto
Processing: damageproto
Processing: xf86driproto
Processing: xcmiscproto
Processing: xextproto
Processing: xproto
Processing: scrnsaverproto
Processing: bigreqsproto
Processing: resourceproto
Processing: fontsproto
Processing: inputproto
Processing: kbproto
Processing: videoproto
Processing: compositeproto
Processing: recordproto
Processing: fontcacheproto
Processing: xf86bigfontproto
Processing: xcb-proto
Processing: libpthread-stubs
Processing: libfontenc
Processing: xtrans
Processing: libdrm
Processing: pixman
Processing: libXau
Processing: libxcb
Processing: libXfont
Processing: libXdmcp
Processing: libX11
Processing: libxkbfile
Processing: libXrender
Processing: libXfixes
Processing: libXdamage
Processing: libpciaccess
Processing: fontutil
Processing: libXext
Processing: libICE
Processing: libSM
Processing: cairo
Processing: alsa-lib
Processing: libxml2
Processing: mysql
Processing: libid3tag
Processing: libmad
Processing: udev
Processing: liboil
Processing: gstreamer-core
Processing: gst-plugins-base
Processing: gst-plugins-good
Processing: gst-plugins-bad
Build path taken because: directory build, no prebuilt rpm,
scbuild/scdeploy already unpacked package
CCgstcdaudio.o
gstcdaudio.c:25:21: fatal error: cdaudio.h: No such file or directory
compilation terminated.
make[3]: *** [libgstcdaudio_la-gstcdaudio.lo] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
error: Bad exit status from /opt/freescale/ltib/tmp/rpm-tmp.20261 (%build)
RPM build errors:
Build time for gst-plugins-bad: 51 seconds
Failed building gst-plugins-bad
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Thu Nov 21 15:03:38 2013
Ended:   Thu Nov 21 15:04:39 2013
Elapsed: 61 seconds
These packages failed to build:
gst-plugins-bad
Build Failed
Exiting on error or interrupt
Can anyone help me?
lionxmx
Build path taken because: directory build, build key set, no prebuilt rpm,
rpmbuild --dbpath /opt/freescale/ltib/rootfs//var/lib/rpm --target arm --define '_unpackaged_files_terminate_build 0' --define '_target_cpu arm' --define '__strip strip' --define '_topdir /opt/freescale/ltib/rpm' --define '_prefix /usr' --define '_tmppath /opt/freescale/ltib/tmp' --define '_rpmdir /opt/freescale/ltib/rpm/RPMS'  --define '_mandir /usr/share/man' --define '_sysconfdir /etc' --define '_localstatedir /var' -bc --short-circuit  /opt/freescale/ltib/dist/lfs-5.1/gst-plugins-bad/gst-plugins-bad.spec
Building target platforms: arm
Building for target arm
Executing(%build): /bin/sh -e /opt/freescale/ltib/tmp/rpm-tmp.20261
+ umask 022
+ cd /opt/freescale/ltib/rpm/BUILD
+ cd gst-plugins-bad-0.10.11
+ ./configure --prefix=/usr --host=arm-linux --build=i686-pc-linux-gnu --disable-valgrind --disable-x --disable-xvid --disable-ximagesrc --disable-jack --disable-sdl --disable-sdltest --x-includes= --x-libraries= --without-check NM=nm
configure: WARNING: unrecognized options: --disable-x, --disable-ximagesrc, --without-check
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for arm-linux-strip... arm-linux-strip
checking nano version... 0 (release)
checking whether to enable maintainer-specific portions of Makefiles... no
checking build system type... i686-pc-linux-gnu
checking host system type... arm-unknown-linux-gnu
checking for style of include used by make... GNU
checking for arm-linux-gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... yes
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... ld
checking if the linker (ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... nm
checking the name lister (nm) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for ld option to reload object files... -r
checking how to recognize dependent libraries... pass_all
checking for arm-linux-ar... ar
checking for arm-linux-strip... (cached) arm-linux-strip
checking for arm-linux-ranlib... arm-linux-ranlib
checking command to parse nm output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking whether NLS is requested... yes
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for ld used by GCC... ld
checking for shared library run path origin... done
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking for arm-linux-pkg-config... no
checking for pkg-config... /opt/freescale/ltib/usr/bin/pkg-config
configure: WARNING: using cross tools not prefixed with host triplet
checking pkg-config is at least version 0.9.0... yes
configure: Using GStreamer Bad Plug-ins source release as package name
configure: Using Unknown package origin as package origin
configure: *** checking feature: building of plug-ins with external deps ***
configure: building external plug-ins
configure: *** checking feature: building of experimental plug-ins ***
configure: not building experimental plug-ins
checking whether byte ordering is bigendian... no
checking whether byte ordering is bigendian... (cached) no
checking for arm-linux-gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether we are using the GNU C++ compiler... (cached) yes
checking whether g++ accepts -g... (cached) yes
checking dependency style of g++... (cached) gcc3
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... ld
checking whether the g++ linker (ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking for g++... yes
checking for arm-linux-objcc... no
checking for arm-linux-objc... no
checking for arm-linux-gcc... arm-linux-gcc
checking dependency style of arm-linux-gcc... gcc3
checking if Objective C compiler works... no
checking whether gcc and cc understand -c and -o together... yes
checking for working do while(0) macros... yes
checking for valgrind... no
checking whether to build gtk-doc documentation... no
checking for gtkdoc-check... no
configure: Looking for Python version >= 2.1
checking for python... /usr/bin/python
checking "/usr/bin/python":... okay
checking local Python configuration... looks good
checking whether to build plugin documentation... no (gtk-doc disabled or not available)
checking for cos in -lm... yes
checking for stdlib.h... (cached) yes
checking for unistd.h... (cached) yes
checking for getpagesize... yes
checking for working mmap... no
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for stdint types... stdint.h (shortcircuit)
make use of stdint.h in _stdint.h (assuming C99 compatible system)
checking for FIONREAD in sys/ioctl.h... yes
checking if compiler supports gcc-style inline assembly... yes
checking for socket... yes
checking for gethostbyname... yes
checking for GLIB... yes
checking for LIBOIL... yes
checking for GST... yes
configure: using GStreamer tools in /opt/freescale/ltib/rootfs/usr/bin
configure: using GStreamer plug-ins in /opt/freescale/ltib/rootfs/usr/lib/gstreamer-0.10
checking for GST_BASE... yes
checking for GST_GDP... yes
checking for GST_CHECK... yes
checking for GST_CONTROLLER... yes
checking for GST_PLUGINS_BASE... yes
configure: using GStreamer Base Plug-ins in /opt/freescale/ltib/rootfs/usr/lib/gstreamer-0.10
configure: Using GStreamer Base Plugins in /opt/freescale/ltib/rootfs/usr/lib/gstreamer-0.10
checking for GTK... no
checking for GLADE... no
checking for X11... yes
configure: Using /usr/lib/gstreamer-0.10 as the plugin install location
checking to see if compiler understands -Wall... yes
checking to see if compiler understands -Wdeclaration-after-statement... yes
checking to see if compiler understands -Wvla... yes
checking to see if compiler understands -Wpointer-arith... yes
configure: set ERROR_CFLAGS to -Wall -Wdeclaration-after-statement -Wvla -Wpointer-arith
checking to see if c++ compiler understands ... yes
checking to see if c++ compiler understands -Wall... yes
configure: set ERROR_CXXFLAGS to -Wall
configure: WARNING: Not building real plugin, only works on 32bit and 64bit x86 platforms
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking winsock2.h usability... no
checking winsock2.h presence... no
checking for winsock2.h... no
configure: *** checking feature: QuickTime wrapper ***
configure: *** for plug-ins: qtwrapper ***
checking QuickTime/Movies.h usability... no
checking QuickTime/Movies.h presence... no
checking for QuickTime/Movies.h... no
configure: *** These plugins will not be built: qtwrapper
configure: *** checking feature: Video CD ***
configure: *** for plug-ins: vcdsrc ***
checking linux/cdrom.h usability... yes
checking linux/cdrom.h presence... yes
checking for linux/cdrom.h... yes
configure: *** These plugins will be built: vcdsrc
configure: *** checking feature: alsa plug-ins ***
configure: *** for plug-ins: gstalsa ***
checking for ALSA... yes
configure: *** These plugins will be built: gstalsa
configure: *** checking feature: ASS/SSA renderer ***
configure: *** for plug-ins: assrender ***
checking for ASSRENDER... no
no
configure: *** These plugins will not be built: assrender
configure: *** checking feature: amrwb library ***
configure: *** for plug-ins: amrwb ***
checking for GP3D_IF_decode in -lamrwb... no
configure: *** These plugins will not be built: amrwb
configure: *** checking feature: AirPort Express Wireless sink ***
configure: *** for plug-ins: apexsink ***
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for OpenSSL directory... /usr
configure: *** These plugins will be built: apexsink
configure: *** checking feature: bz2 library ***
configure: *** for plug-ins: bz2 ***
checking for BZ2_bzCompress in -lbz2... no
configure: *** These plugins will not be built: bz2
configure: *** checking feature: cdaudio ***
configure: *** for plug-ins: cdaudio ***
checking for libcdaudio-config... /usr/bin/libcdaudio-config
configure: *** These plugins will be built: cdaudio
configure: *** checking feature: celt ***
configure: *** for plug-ins: celt ***
checking for CELT... no
no
configure: *** These plugins will not be built: celt
configure: *** checking feature: libdc1394 ***
configure: *** for plug-ins: dc1394 ***
checking for LIBDC1394... no
no
configure: *** These plugins will not be built: dc1394
configure: *** checking feature: directfb ***
configure: *** for plug-ins: dfbvideosink  ***
checking for DIRECTFB... no
no
configure: *** These plugins will not be built: dfbvideosink
configure: *** checking feature: dirac ***
configure: *** for plug-ins: dirac ***
checking for DIRAC... no
no
configure: *** These plugins will not be built: dirac
configure: *** checking feature: dts library ***
configure: *** for plug-ins: dtsdec ***
checking for dca_init in -ldca... no
checking for dts_init in -ldts_pic... no
configure: *** These plugins will not be built: dtsdec
configure: *** checking feature: divx plugins ***
configure: *** for plug-ins: divx ***
checking encore2.h usability... no
checking encore2.h presence... no
checking for encore2.h... no
configure: WARNING: Divx4linux encore headers not found
configure: *** These plugins will not be built: divx
configure: *** checking feature: dvdnav library ***
configure: *** for plug-ins: resindvd ***
checking for dvdnav-config... no
configure: *** These plugins will not be built: resindvd
configure: *** checking feature: METADATA muxer and demuxer ***
configure: *** for plug-ins: metadata ***
checking for EXIF... no
checking for IPTC... no
checking for XMP... no
checking for XMP_1_99_5... no
no
configure: WARNING: no of metadata libraries (exif, iptc or xmp) found
configure: *** These plugins will not be built: metadata
configure: *** checking feature: AAC encoder plug-in ***
configure: *** for plug-ins: faac ***
checking for faacEncOpen in -lfaac... no
configure: *** These plugins will not be built: faac
configure: *** checking feature: AAC decoder plug-in ***
configure: *** for plug-ins: faad ***
checking for faacDecOpen in -lfaad... no
checking for NeAACDecOpen in -lfaad... no
configure: *** These plugins will not be built: faad
configure: *** checking feature: linux framebuffer ***
configure: *** for plug-ins: fbdevsink ***
checking linux/fb.h usability... yes
checking linux/fb.h presence... yes
checking for linux/fb.h... yes
configure: *** These plugins will be built: fbdevsink
configure: *** checking feature: GSM library ***
configure: *** for plug-ins: gsmenc gsmdec ***
checking for gsm_create in -lgsm... no
checking for gsm_create in -lgsm... (cached) no
configure: *** These plugins will not be built: gsmenc gsmdec
configure: *** checking feature: integer vorbis plug-in ***
configure: *** for plug-ins: ivorbisdec ***
checking for vorbis_block_init in -lvorbisidec... no
configure: *** These plugins will not be built: ivorbisdec
configure: *** checking feature: Jack ***
configure: *** for plug-ins: jack ***
configure: *** These plugins will not be built: jack
configure: *** checking feature: jp2k ***
configure: *** for plug-ins: jp2kdec jp2kenc ***
checking for jas_stream_fopen in -ljasper... no
configure: *** These plugins will not be built: jp2kdec jp2kenc
configure: *** checking feature: ladspa ***
configure: *** for plug-ins: ladspa ***
checking ladspa.h usability... no
checking ladspa.h presence... no
checking for ladspa.h... no
checking for LRDF... no
configure: *** These plugins will not be built: ladspa
configure: *** checking feature: mms protocol library ***
configure: *** for plug-ins: libmms ***
checking for LIBMMS... no
no
configure: *** These plugins will not be built: libmms
configure: *** checking feature: modplug ***
configure: *** for plug-ins: modplug ***
checking for MODPLUG... no
configure: *** These plugins will not be built: modplug
configure: *** checking feature: libmimic library ***
configure: *** for plug-ins: mimic ***
checking for MIMIC... no
configure: *** These plugins will not be built: mimic
checking for MJPEG... no
configure: *** checking feature: mpeg2enc ***
configure: *** for plug-ins: mpeg2enc ***
checking for MPEG2ENC... no
configure: *** These plugins will not be built: mpeg2enc
configure: *** checking feature: mplex ***
configure: *** for plug-ins: mplex ***
checking for MPLEX... no
configure: *** These plugins will not be built: mplex
configure: *** checking feature: musepackdec ***
configure: *** for plug-ins: musepack ***
checking mpc/mpcdec.h usability... no
checking mpc/mpcdec.h presence... no
checking for mpc/mpcdec.h... no
checking mpcdec/mpcdec.h usability... no
checking mpcdec/mpcdec.h presence... no
checking for mpcdec/mpcdec.h... no
configure: *** These plugins will not be built: musepack
configure: *** checking feature: musicbrainz tag generation ***
configure: *** for plug-ins: musicbrainz ***
checking for MUSICBRAINZ... no
configure: *** These plugins will not be built: musicbrainz
configure: *** checking feature: MythTV client plugins ***
configure: *** for plug-ins: mythtvsrc ***
checking for GMYTH... no
no
configure: *** These plugins will not be built: mythtvsrc
checking for X... libraries , headers
configure: *** checking feature: nas plug-in ***
configure: *** for plug-ins: nassink ***
checking for gethostbyname... (cached) yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking X11/Xlib.h usability... yes
checking X11/Xlib.h presence... yes
checking for X11/Xlib.h... yes
checking for AuOpenServer in -laudio... no
configure: *** These plugins will not be built: nassink
configure: *** checking feature: neon http client plugins ***
configure: *** for plug-ins: neonhttpsrc ***
checking for NEON... no
no
configure: *** These plugins will not be built: neonhttpsrc
configure: *** checking feature: ofa plugins ***
configure: *** for plug-ins: ofa ***
checking for OFA... no
no
configure: *** These plugins will not be built: ofa
configure: *** checking feature: timidity midi soft synth plugin ***
configure: *** for plug-ins: timidity ***
checking for TIMIDITY... no
no
configure: *** These plugins will not be built: timidity
configure: *** checking feature: wildmidi midi soft synth plugin ***
configure: *** for plug-ins: wildmidi ***
checking wildmidi_lib.h usability... no
checking wildmidi_lib.h presence... no
checking for wildmidi_lib.h... no
configure: WARNING: no WildMidi library found (libWildMidi)
configure: *** These plugins will not be built: wildmidi
configure: *** checking feature: SDL plug-in ***
configure: *** for plug-ins: sdlvideosink sdlaudiosink ***
configure: *** These plugins will not be built: sdlvideosink sdlaudiosink
configure: *** checking feature: sndfile plug-in ***
configure: *** for plug-ins: sfsrc sfsink ***
checking for SNDFILE... no
configure: *** These plugins will not be built: sfsrc sfsink
configure: *** checking feature: soundtouch plug-in ***
configure: *** for plug-ins: soundtouch ***
checking for SOUNDTOUCH... no
configure: *** These plugins will not be built: soundtouch
configure: *** checking feature: spc decoder ***
configure: *** for plug-ins: spc ***
checking openspc.h usability... no
checking openspc.h presence... no
checking for openspc.h... no
configure: *** These plugins will not be built: spc
configure: *** checking feature: swfdec plug-in ***
configure: *** for plug-ins: swfdec ***
checking for SWFDEC... no
no
configure: *** These plugins will not be built: swfdec
configure: *** checking feature: ogg theora codec ***
configure: *** for plug-ins: theoraexpdec ***
checking for THEORADEC... no
no
configure: *** These plugins will not be built: theoraexpdec
configure: *** checking feature: x264 plug-in ***
configure: *** for plug-ins: x264 ***
checking for x264_nal_encode in -lx264... no
configure: *** These plugins will not be built: x264
configure: *** checking feature: xvid plugins ***
configure: *** for plug-ins: xvid ***
configure: *** These plugins will not be built: xvid
configure: *** checking feature: DVB Source ***
configure: *** for plug-ins: dvb ***
checking Checking for up to date dvb installation... checking linux/dvb/frontend.h usability... yes
checking linux/dvb/frontend.h presence... yes
checking for linux/dvb/frontend.h... yes
configure: *** These plugins will be built: dvb
configure: *** checking feature: Open Sound System 4 ***
configure: *** for plug-ins: oss4 ***
checking Checking if we can build the OSS4 elements... checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking for sys/stat.h... (cached) yes
checking for sys/types.h... (cached) yes
configure: *** These plugins will be built: oss4
configure: *** checking feature: Windows internet library ***
configure: *** for plug-ins: wininet ***
checking Checking for windows internet support... checking windows.h usability... no
checking windows.h presence... no
checking for windows.h... no
checking wininet.h usability... no
checking wininet.h presence... no
checking for wininet.h... no
configure: *** These plugins will not be built: wininet
configure: *** checking feature: Windows ACM library ***
configure: *** for plug-ins: acm ***
checking Checking for ACM support... checking for windows.h... (cached) no
checking msacm.h usability... no
checking msacm.h presence... no
checking for msacm.h... no
configure: *** These plugins will not be built: acm
checking for sed... /bin/sed
configure: creating ./config.status
config.status: creating Makefile
config.status: creating common/shave
config.status: creating common/shave-libtool
config.status: creating gst-plugins-bad.spec
config.status: creating gst/Makefile
config.status: creating gst/aacparse/Makefile
config.status: creating gst/aiffparse/Makefile
config.status: creating gst/amrparse/Makefile
config.status: creating gst/autoconvert/Makefile
config.status: creating gst/legacyresample/Makefile
config.status: creating gst/liveadder/Makefile
config.status: creating gst/bayer/Makefile
config.status: creating gst/camerabin/Makefile
config.status: creating gst/cdxaparse/Makefile
config.status: creating gst/dccp/Makefile
config.status: creating gst/deinterlace/Makefile
config.status: creating gst/deinterlace2/Makefile
config.status: creating gst/dtmf/Makefile
config.status: creating gst/dvdspu/Makefile
config.status: creating gst/festival/Makefile
config.status: creating gst/flv/Makefile
config.status: creating gst/freeze/Makefile
config.status: creating gst/h264parse/Makefile
config.status: creating gst/librfb/Makefile
config.status: creating gst/mpegdemux/Makefile
config.status: creating gst/mpegtsmux/Makefile
config.status: creating gst/mpegtsmux/tsmux/Makefile
config.status: creating gst/mpeg4videoparse/Makefile
config.status: creating gst/mpegvideoparse/Makefile
config.status: creating gst/mve/Makefile
config.status: creating gst/mxf/Makefile
config.status: creating gst/nsf/Makefile
config.status: creating gst/nuvdemux/Makefile
config.status: creating gst/pcapparse/Makefile
config.status: creating gst/qtmux/Makefile
config.status: creating gst/rawparse/Makefile
config.status: creating gst/rtpmanager/Makefile
config.status: creating gst/rtpmux/Makefile
config.status: creating gst/scaletempo/Makefile
config.status: creating gst/sdp/Makefile
config.status: creating gst/selector/Makefile
config.status: creating gst/siren/Makefile
config.status: creating gst/speed/Makefile
config.status: creating gst/subenc/Makefile
config.status: creating gst/stereo/Makefile
config.status: creating gst/tta/Makefile
config.status: creating gst/valve/Makefile
config.status: creating gst/videosignal/Makefile
config.status: creating gst/vmnc/Makefile
config.status: creating gst/real/Makefile
config.status: creating gst/xdgmime/Makefile
config.status: creating gst/y4m/Makefile
config.status: creating gst-libs/Makefile
config.status: creating gst-libs/gst/Makefile
config.status: creating gst-libs/gst/dshow/Makefile
config.status: creating gst-libs/gst/interfaces/Makefile
config.status: creating sys/Makefile
config.status: creating sys/dshowdecwrapper/Makefile
config.status: creating sys/acmenc/Makefile
config.status: creating sys/acmmp3dec/Makefile
config.status: creating sys/dshowsrcwrapper/Makefile
config.status: creating sys/dshowvideosink/Makefile
config.status: creating sys/dvb/Makefile
config.status: creating sys/fbdev/Makefile
config.status: creating sys/oss4/Makefile
config.status: creating sys/qtwrapper/Makefile
config.status: creating sys/vcd/Makefile
config.status: creating sys/wasapi/Makefile
config.status: creating sys/wininet/Makefile
config.status: creating sys/winks/Makefile
config.status: creating sys/winscreencap/Makefile
config.status: creating tests/examples/Makefile
config.status: creating tests/examples/directfb/Makefile
config.status: creating tests/examples/mxf/Makefile
config.status: creating tests/examples/scaletempo/Makefile
config.status: creating tests/examples/switch/Makefile
config.status: creating ext/amrwb/Makefile
config.status: creating ext/alsaspdif/Makefile
config.status: creating ext/assrender/Makefile
config.status: creating ext/apexsink/Makefile
config.status: creating ext/bz2/Makefile
config.status: creating ext/cdaudio/Makefile
config.status: creating ext/celt/Makefile
config.status: creating ext/dc1394/Makefile
config.status: creating ext/dirac/Makefile
config.status: creating ext/directfb/Makefile
config.status: creating ext/divx/Makefile
config.status: creating ext/dts/Makefile
config.status: creating ext/metadata/Makefile
config.status: creating ext/faac/Makefile
config.status: creating ext/faad/Makefile
config.status: creating ext/gsm/Makefile
config.status: creating ext/ivorbis/Makefile
config.status: creating ext/jack/Makefile
config.status: creating ext/jp2k/Makefile
config.status: creating ext/ladspa/Makefile
config.status: creating ext/libmms/Makefile
config.status: creating ext/Makefile
config.status: creating ext/nas/Makefile
config.status: creating ext/modplug/Makefile
config.status: creating ext/mpeg2enc/Makefile
config.status: creating ext/mimic/Makefile
config.status: creating ext/mplex/Makefile
config.status: creating ext/musepack/Makefile
config.status: creating ext/musicbrainz/Makefile
config.status: creating ext/mythtv/Makefile
config.status: creating ext/neon/Makefile
config.status: creating ext/ofa/Makefile
config.status: creating ext/resindvd/Makefile
config.status: creating ext/sdl/Makefile
config.status: creating ext/sndfile/Makefile
config.status: creating ext/soundtouch/Makefile
config.status: creating ext/spc/Makefile
config.status: creating ext/swfdec/Makefile
config.status: creating ext/theora/Makefile
config.status: creating ext/timidity/Makefile
config.status: creating ext/x264/Makefile
config.status: creating ext/xvid/Makefile
config.status: creating po/Makefile.in
config.status: creating docs/Makefile
config.status: creating docs/plugins/Makefile
config.status: creating docs/plugins/figures/Makefile
config.status: creating docs/version.entities
config.status: creating common/Makefile
config.status: creating common/m4/Makefile
config.status: creating m4/Makefile
config.status: creating tests/Makefile
config.status: creating tests/check/Makefile
config.status: creating tests/icles/Makefile
config.status: creating win32/common/config.h
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing po-directories commands
config.status: creating po/POTFILES
config.status: executing _stdint.h commands
config.status: creating _stdint.h : _GST_PLUGINS_BAD__STDINT_H
config.status: _stdint.h is unchanged
configure: *** Plug-ins without external dependencies that will be built:
    aacparse
    aiffparse
    amrparse
    autoconvert
    bayer
    camerabin
    cdxaparse
    dccp
    deinterlace
    deinterlace2
    dtmf
    dvdspu
    festival
    flv
    freeze
    h264parse
    legacyresample
    librfb
    liveadder
    mpeg4videoparse
    mpegdemux
    mpegtsmux
    mpegvideoparse
    mve
    mxf
    nsf
    nuvdemux
    pcapparse
    qtmux
    rawparse
    rtpmanager
    rtpmux
    scaletempo
    sdp
    selector
    siren
    speed
    stereo
    subenc
    tta
    valve
    videosignal
    vmnc
    xdgmime
    y4m
configure: *** Plug-ins without external dependencies that will NOT be built:
    real
configure: *** Plug-ins with dependencies that will be built:
    apexsink
    cdaudio
    dvb
    fbdevsink
    gstalsa
    oss4
    vcdsrc
configure: *** Plug-ins with dependencies that will NOT be built:
    acm
    amrwb
    assrender
    bz2
    celt
    dc1394
    dfbvideosink
    dirac
    divx
    dtsdec
    faac
    faad
    gsmenc gsmdec
    ivorbisdec
    jack
    jp2kdec jp2kenc
    ladspa
    libmms
    metadata
    mimic
    modplug
    mpeg2enc
    mplex
    musepack
    musicbrainz
    mythtvsrc
    nassink
    neonhttpsrc
    ofa
    qtwrapper
    resindvd
    sfsrc sfsink
    soundtouch
    spc
    swfdec
    theoraexpdec
    timidity
    wildmidi
    wininet
    x264
    xvid
+ make
Making all in gst-libs
Making all in gst
Making all in interfaces
Making all in gst
Making all in aacparse
Making all in aiffparse
Making all in amrparse
Making all in autoconvert
Making all in camerabin
Making all in legacyresample
Making all in bayer
Making all in cdxaparse
Making all in dccp
Making all in deinterlace
Making all in deinterlace2
Making all in dtmf
Making all in dvdspu
Making all in festival
Making all in flv
Making all in freeze
Making all in h264parse
Making all in librfb
Making all in liveadder
Making all in mpegdemux
Making all in mpegtsmux
Making all in tsmux
Making all in mpeg4videoparse
Making all in mpegvideoparse
Making all in mve
Making all in mxf
Making all in nsf
Making all in nuvdemux
Making all in pcapparse
Making all in qtmux
Making all in rawparse
Making all in rtpmanager
Making all in rtpmux
Making all in scaletempo
Making all in sdp
Making all in selector
Making all in siren
Making all in speed
Making all in subenc
Making all in stereo
Making all in tta
Making all in valve
Making all in videosignal
Making all in vmnc
Making all in xdgmime
Making all in y4m
Making all in sys
Making all in dvb
Making all in fbdev
Making all in oss4
Making all in vcd
Making all in ext
Making all in alsaspdif
Making all in apexsink
Making all in cdaudio
  CC    gstcdaudio.o
RPM build errors:
