I am using CW10.4 and MQX4.0.2.
When I try the httpsrv project itself, it works very well.
But when I keep adding my code to this project, the TCP/IP out of memory happens intermediately after I run the project .
When I delete some code, then it works again. It seems that there is no enough memory for the whole code to run.
I looked through the link file intflash.lcf , but have no idea how to increase it. I also upload the link file.
Any ideas or suggestion will be appreciated.
-Daniel
Original Attachment has been moved to: intflash.lcf.zip
