what i did is
just power on the board,
it booted with default configuration, i did not change anything
it came up with an prompt
logged in to the board with root user
then tried to assign a ip to the board
but no Ethernet interface??
Do you use USDPAA dtb? If so, all the ethernet ports have been assigned to USDPAA, so you cannot see them in Linux Kernel.
