MX6 i2C linux driver
Question asked by karstenklein on Nov 15, 2013
Latest reply on Feb 26, 2014 by Yixing Kong
Hi all,
I currently work with the MCIMMX6Q-SDB board from Freescale. The kernel is taken from Yocto/Dylan core-image-base as it is, without change in config.
I tried to write a small userspace-application which uses the accelerator MMA8451 via I2C.
I figured out how the MMA is connected to the CPU and tried to do the following:
dev = open ("/dev/i2c-0", O_RDWR);
    if (dev < 0) {
   err = errno;
   perror("==> ERROR  open:");
   printf("errno = %d\n", err);
   close(dev);
   exit (1);
    if (ioctl(dev, I2C_SLAVE, I2C_DEV_ADR_MMA8451) < 0) {
   err = errno;
   perror("==> Error ioctl:");
   close(dev);
   exit (1);
The syscall ioclt comes up with the following error;
==> Error ioctl:: Device or resource busy
errno = 16
If I use
if (ioctl(dev, I2C_SLAVE_FORCE, I2C_DEV_ADR_MMA8451) < 0) {
instead, the I2C basicly works.
After some search, I found the following:
root@imx6qsabresd:/sys/devices/virtual/input/input3# cat name
mma845x
So this makes me thinking, that there is a virtual device driver in the system which uses the i2c-driver as well.
But I cant find any informations about this.
Does anyone have experience on that ?
Karsten
